How to set up gaming audio
Hi all, I have a problem and there’s probably an easy answer I am not seeing. I have a DT880 Chrome Edition (250 Ohm) connected to a Liquid Spark that is connected to a Fiio E10K which is connected over usb to my PC. If I take a microphone with a 3.5mm jack and hook that up to the line in of the PC everything works fine in something like Discord where I can manage my input and output devices separately. However, in CSGO for instance, I can’t manage them separately so my mic doesn’t work…
Do I really need a Schiit Hell or something like that to be able to use my DT880 in those situations or is there another fix?
Try changing your input default to your microphone in your windows sound options.
Yeah, I figured I was being stupid. That worked perfectly thanks.
