I need an amp for hd58x,elex
So im new and thinking to get an amp that pairs well with d10 dac, hd58x and elex. Im not thinking any other upgrade soon my budget is under 400$ but i prefer if there is a value pick that close to high end
Well, personally I would say perhaps consider an archel 2.5 pro or an asgard 3 (w/o the dac module) imo. I think those have great bang for the buck and preform well with the elex and 58x (the 58x isn’t that picky though)
Hmm, if i get the archel 2.5 ,do i need another dac? I have topping d10
The 2.5 can be run from rca or xlr, so the d10 will work just fine. If you wanted to you could also grab an enog 2 as a stack but it will work no problems with a d10
I don’t know but shipping cost is more than i thought in this options.If there is other good options i would like to check them too
Are you in the US or NA? If not, then the archel is most likely not worth it because it’s going to be too much in europe or uk
Im in turkey
Ah, well then that would change things. Schiit does have an EU store but mostly everything is out of stock. How much is a Lake People G103-S?
I found it on thomann 280$ shipping incl, is it similar to other amps that you suggested?
I think it is higher preforming, but it is more expensive. It’s a very clean and accurate amplifier and should be pretty nice
Hmm ,if you think its better than archel 2.5 for elex i can afford it, price is good
I would personally say so imo
I suppose the RNHP is out of budget. :confused:
