I need help to find ANC headphones that worked with a wired connection
A police client of mine asked for some Bose QuietComfort Ultra’s, but I don’t sell Bose…or Sony and when I told them that came back asking if I have anything similar to suggest. it’s for their stenographer’s and the Bt won’t be used at all.
I found the Evolve2 85, but still working on determining if the ANC works when wired.
thanks!
Sennheiser 4.50 BTNC still runs its ANC when wired, just changes the ANC on/off function to be on the power button (short single press). Not the greatest ANC in the world tho, might not help a stenographer much.
thanks @donjoe0 alas, those are on-ear and they want over-ear. I know they are on-ear because I used to own them.
Hah! Never seen an on-ear designed in this size, I think they’re just the stupidest over-ears with way too narrow - though tall enough - of an ear-hole in them. But yeah, since the pads went to shit and I replaced them with bigger HM5 sized ones I almost forgot what crap pad design they have stock. Welp, don’t know any other ones then.
yeh, m0ds like that aren’t something the RCMP are going to do, LoL!
