i need a dac/amp for my HiFiGo AFUL Explorer for both my phone and laptop because i use them equally while listening to music preferably under 90 bucks any recs?
I’ve had both the $9 Apple 3.5mm adapter and still like it, but the Tanchjim Space is around $80 and a clear upgrade, especially on the 4.4mm side. Audiosciencereview did measurements on both. At their price points they’re worth it.
The Explorer is very easy to drive so anything should do it. @Dunring made solid recs.
thanks for the rec just bought the tanchjim space
