IEM for samsung galaxy s10 plus
Hello everyone im looking for a set of iem’s that should be an ideal pairing with my samsung galaxy s10 plus. Preferably around the $80 to $100 budget. All help is appreciated. Has to have a warm sound and great soundstage. Easy to drive as i do not own a portable amp but i do own a Soundblasterx g6 that i could use.
If you don’t need a removable cable? then Final Audio E3000 would be a good option :+1:
I wouldnt call the E3000 easy to drive though.
Soundblasterx g6 does that have the :muscle: :man_shrugging:
The E4000 are ok off of MacBook Pro :+1:
Honestly I dont think that a big soundstage and a warm tonality is available in the price range that OP wants…
Because it is easier for an iem to have a big soundstage with a brighter tonality.
They can power my soul byrds well which are 18 ohms. How many are the e3000. The g6 can also power my dt990 pro 250 ohms.
Then it’ll easily drive the E3000’s :+1:
I’ll consider these are there any that i can remove the wire and change it for one that can change tracks.
I use BGVP DMG, warm tonality and tunable !
BGVP DMG, Cheers ! :headphones:
Oh man those look nice are they hard to drive? I also found a review that z reviews did im about to watch it.
Not at all… they have 18 ohms and a sensitivity of 110dB/mW… They can be really loud… And have excellent details retreival with naturalness.
There are several reviews on DMGs
This is a great review:
Onother great review, and pricing is there what you requested $100ish (today… 2021).
My beyerdynamic soul byrds just quit on me only the right side works and now im looking for a replacement in the $50 range.
