IEM Recommendations
Looking for IEM recommendations for gaming. Comfort is mainly what I’m interested in. 100-200$ budget
I don’t have any recommendation but would advice to check the weight on iem’s. Avoid stuff like the moondrop Aria interms of comfort. As much the great sound it delivers the weight pulls the iems out of your ear and requires you to constantly adjust them.
Obligatory Tripowin Olina rec - Comfy, quality, images well and modifiable to taste. $100, less if you go used or shop around.
