You’ll need to take a file to the blon’s though!
I thought the blons were QDC (a lesser used 2-pin industry standard. used in KZ’s and TRN M10) so got meself a nice 2.5mm balanced QDC cable.
Guess what. QDC is oval. BLOn is rectangled… You have to file off the damn corners of the connector on the earbud!
Their cables are soft enough for the so called “ear hooks” to be not ear hooks at all.
I ordered QDC once and they sent 2 pin, i guess i got lucky lol.
Just send them pictures off the blon cable and they’ll make it for you with that connector without extra cost. That’s the best part of XINHS imo, very flexible and great value.
Problem is not the earhook. Look at the connector itself. It’s at an angle… This seems to always be the case with QDC, no matter the brand.
You can fit 2-pin in QDC?!?!?!?!
well, yeah, it just sits on top of the connector protrusion on BL03, but it fits perfectly.
The pins are spaced the same and have the same width, that yellow cable is a 2 pin cable.
In that case. My Yinyoo QDC and MMCX cables are earhookless and of excellent quality. I accidentally received a 2-pin from them too. I’ll check if they’re earhookless too
Here’s the BL03 wearing a Jcally 2 pin cable, works well, its even more comfortable, since it doesn’t press against the ears like the curved connectors do.
Ask them to remove it, no problem.
Do you have a link for them?
