Not that Odin and U12t aren’t amazing…but let’s keep it under like $500?
Looking at ZAS, I pretty much like everything it does, except the treble is a touch too hot. Even harder hitting bass, and/or bass with better detail/definition at the same quantity as ZAS, would be amazing. Guess it’s hard to find really impressive bass?
Tried Szalayi, Meteor. Performer 5 is muddier & darker sounding than ZAS. Hook-X is less hot, but also poorer bass. EA200 is metallic and a bit hot. Perhaps the 14 new KZ’s I haven’t tried yet are worth trying. KBear Believe bass was pretty solid, but fatiguing as hel.
I’m sure Brandon calls me crazy for justifying the price of the Minis but, I find that the minis have exceptional bass performance both in quantity and quality. The soundstage has good depth, and acceptable width but it won’t blow your socks off. It’s not as wide as something like the Tri Starsea. But if bass and clarity is your thing for under $500, the Minis are most likely the best way to go. If you just said Bass and nothing else, I’d rec the Rosefinch on the budget end, then the Legato if you wanted to spend a little more.
Legato was pretty unclear sounding, IIRC. Definitely not one of my best purchases :\ I would take FH3 or JD7 over it. Meteor’s bass was more disappointing than it’s treble/clarity, IIRC, but I didn’t find out that it was all BA til after buying it(#scammed).
Yeah the Maestro Mini is definitely the basshead pick under $500. I love em, my only negative is that they start to sound a bit shouty when you crank the volume to really get the bass pounding.
I have to EQ the higher frequencies to the Maestro SE and that fixes it perfectly for me.
ISN EST50 has solid sub bass without drowning the highs. Would stay away from Maestro Mini until scarlet mini reviews come out. Which is supposed to be a upgrade, even tho they are not calling it that but more bass plus a new driver for highs.
I found them pretty clear for the price range, considering they are bass heavy iem. offcourse they wont be able to compete against a TOTL. Everybody to their own i guess
More clarity than Legato and Performer 5, at least? Something like FH3/Hook-X level clarity? Timeless clarity is pretty much ideal/perfect. (planar ) Penons/ISNs always seem to be rather soft and romantic, from the ones I’ve tried so far. Esp Orb. Fan was terrible lol.
