I would probably want to buy another portable cable anyway because the desktop cable I purchased is terminated in a 1/4in and itās like 7ft long. And I donāt really want to resort to using the original Audioquest cable. So you feel the balanced out on the Hip Dac outperforms the XD-05?
IMO sound quality yes, power it gets close. Also the bass boost is better on the ifi than the xduoo. Also more portable if that matters to you. You should be able to get like a decently sized 4.4mm bal to 2.5mm jack cable fairly easy
Mine came in yesterday, several days ahead of initial estimates. Unfortunately, I also came down with a headcold and donāt trust my ears too much at the moment. Initial thoughts on itās build though are positive. Itās a well designed and well made unit, at least physically. I can tell itās got more than enough power for the 4XX, but again, donāt trust my ears right now. Iāll get back to you guys on the sound after my head clears.
Feel better.
Looking forward to your impressions. ![]()
My head is clearing and Iāve been listening to the Hip-Dac some via 3.5mm unbalanced. I donāt have any balanced cables yet with a 4.4mm pentacon, which leads me to a questionā¦
Is there any potential issue in getting an adapter that goes 4.4 pentacon to any other type of 4 conductor balanced connection? Any harm done by going from 4.4 pentacon to 4-pin XLR or female trrs? I have some of the latter balanced cables so getting an adapter would be the quickest and simplest solution to checking out the Hip-Dacās balanced output. Thanks!
Nope, if you are staying balanced no issues should occur
Thanks, @M0N. Ordering!
How does this compare to the Nano iDSD BL?
Personally, if you had balanced capable headphones/iems, I would take the hip over the nano, but if you have single ended I might say the nano would be a better pick. Both are great and I donāt think you could go wrong with either imo
Yep the 3.5mm balanced out on the Nano is a ball ache when it comes to cable options ![]()
Well you can just get an adapter and it works, but finding a natively terminated 3.5mm balanced is more difficult
Really I found near impossible to find any male 3.5mm to female 2.5mm/4.4mm balanced adaptors except the Mee Audio cable set ?
This one has worked well for me
Glad I ordered that before @M0Nās recommendation. Now it will surely sell out ;p
It was already popular anyways lol, I donāt have much influence
Yes you do.
I think we should get a little piece of RNHP sales! ![]()
Hart Audio also has a 3.5 balanced interconnect. Iām in the process of migrating entirely to that system.
Aside from iFi are there a lot of brands going 3.5 balanced?
Not really no, but a lot of brands are shifting to 4.4mm bal
The Rupert Neve Fidelice has a 4.4 balanced as well
