The hardest part about the hip DAC is actually trying to find one on sale
It seems perfect for me (though my headphones arenât very bright I love the feature set since mqa might be useful if I stay on tidal and i need something to use on a laptop nonstop) because itâs basically a zendac but the size of a DAP (I need my dac to basically be the length of an LG smartphone).
but amazon doesnât have it and music direct is always waiting for more
Would using a 4.4 mm 2 pin cable on the starfields and connecting to the balanced output on the hip dac make the starfield balanced? Sorry for the possible dumb and probably obvious answer. Haha. Or could i get a 3.5mm to 4.4mm adapter instead? Or Will that not make it truly balanced?
The cable terminating in 4.4 would make them balanced. The adapter would potentially cause grounding issues giving a balanced feed to a single ended cable.
To be clear you canât use a balanced to SE adapter on the OUTPUT of almost any amp without the potential to damage the amp.
You in effect short 2 signal lines from the amps output together, if your lucky the amp designer protected against this, but I wouldnât bet on it.
The 4.4 balanced cable would be fine.
Got the hip dac a couple days ago. It pairs REALLY well with the Starfields. The warmth makes it all ooey gooey. The bass boost can be too much at times but when its good it thumps. Here is my Tidal playlist for my Starfields if anyone is interested
Yea, I was wondering about a portable dac/amp to use that could potentially replace my d10 in the dac department to help fund itâs purchase but then realized this doesnât have a line out. What do you think it would take for a portable dac/amp combo where the dac can perform on a similar or better tier compared to the d10? Assuming the portable dac/amp has a line out to utilize.
In a similar price tier what about an xduoo xd05? No need to recable to be balanced and is a cleaner sounding dac, but I think the d10 is a bit better but itâs hard to compete with desktop dacs on a price to price basis
What about the d10 compared to the dac of the iFi Nano iDSD Black Label? Both compared when using an unbalanced connection and also compared when using the ifi balanced to an amp with balanced inputs.
I am new to the Hifi world and I have to say I learn a lot through this forum
I am currently âequippedâ with the following :
Meze 99 Classics headphone
iFi Hip-DAC
I connect the DAC to a laptop (old Macbook Pro) and use mainly Qobuz for the music source.
To my humble ears I find that both Headphone and DAC pair very well together (without DAC bass boost activated though, since Headphone is already bass friendly)
I have a few questions related to the Hip-DAC.
I recently had issues with the DAC emitting a little âscratchâ noise and disconnecting during use. I was worried it was a problem with the device but it seems due to the blue USB cable provided by iFi. Using another one did not reproduce the issue. Did someone encounter the same problem?
Iâve read the previous posts related to the use of the balance output.
I use it sometimes with a simple 3.5-4.4 adapter plugged directly to the original cable provided by Meze. Do you think that I should use a specific balanced cable instead?
Also do you know if there is a sound difference between the Hip-DAC and the Zen-DAC?
I havenât noticed this issue but I also have not used the iFi provided cable much (or at all?). Iâve been using USB extension cables from Cable Creations that have worked just perfectly.
Iâm assuming the original cable is unbalanced. Generally, balanced-to-unbalanced adapters donât work very well. They combine two signal lines that arenât meant to be combined and put a potentially dangerous load on your amplifier. However, if youâre using a balanced cable already then a 3.5mm balanced to 4.4mm balanced adapter will work just fine.
So for that use case, the ifi idsd nano black label might make more sense imo as it has a line out where the hip dac does not. What headphones are you using?
