Just bought this with the iPower 5V power supply and so far very impressed. I can confirm the XBass function is indeed like butter heroin and the power on offer is crazy.
Iāve also tried some really sensitive IEMās on this and canāt hear any noise floor so very happy, of course have to reduce input volume into the AMP otherwise the IEMās would literally explode from the power output ^^.
Also a perfect match for the notoriously power hungry Tin P1.
I donāt think 1 Watt is a perfect match. I have Hiby R5 and it sounds decent, but I have been considering the A50s or something like it to get more from the P1. Although I do envy you that bass boost button
I can max out the comfortable listening level of the P1ās on a Fiio M9 (220mW) but they donāt sound as open as the Hiby R5 which is why I suspect a move to a beefier amp would affect the sound not just the loudness. Could be wrong though, itās just all the reviewers beat that message/drum to death!
This made my day ahah Iām a similar user to you Roknar, Iāve got my first more serious setup recently (Hd6xx + L30+E30), but after the L30 fiasco, I returned the stack and got a zen dac + zen can stack, to pair with the HD 6xx. Reading this review doesnāt make me happier about my choice (I understand that this amp could distort the lower end a bit with the 300ohm of the 6xx) but then you say Itās doing ok with your 600ohms dt880, I guess Iāll evaluate the stack as soon as I get it in my hands
On the pentaconn connection, Iām sitting at gain setting of 3 at around 9 oāclock and 11-12 is where it starts getting painfully loud to me. I hear no distortion. To hear distortion I have to switch to RCA and dial up the bass on the tube preamp, so that is with the variable setting, meaning the DAC is doing some pre-amping as well as the tube preamp, and then I have to go to 12 on the Bass dial for that to happen (usually I have that at the minimum).
At those settings, the headphones are physically rumbling, though understandably the sound is rather dark, but if I want all the bass, there is that option. So yea, I donāt have anything to compare too, and I could see that maybe with more power, I could get the added bass without darkening the sound. But itās definitely fine without the preamp lol. I see there is more headroom o upgrade in the future, but I donāt regret my purchase at all. Also, truebass is some kind of black magic that adds bass without making things sound dark.
That is very nice to hear. I am now 100% sure this stack will do it for me for a long time I love having options and knowing that the truebass is really viable is nice. Also, about the distortion, I doubt Iāll hear any of it, and even than, Iād just adjust my volume and settings accordingly. Thank you for your input I strongly appreciate it.
Iām waiting for some new headphones to arrive to really test out the Zen Can, but I tried some 16ohm headphones to see how it worked last night, and there is a slight buzz/noise when the music is quiet. I would call this surface noise if it was vinyl, but it happens with digital as well. It gets louder as I mess with the volume. Happens with different sources (however they are through the same switch/wire to the Zen Can).
Is this likely just because of too much power for the cheap low impedance headphones? Or is this an interference issue Iāll need to troubleshoot?
I have no experience with this kind of issueā¦but from what Iāve read, itās usually caused by a short / ground loop with the cables or other piece of equipment.
yes itās ground loop issue. Put 3.5mm to 3.5mm cable to 3.5 input on Zen Can, and put other end of this cable to any output on PC motherboard then hiss will go away. I have same amp
Canāt figure it out⦠definitely a ground loop issue, but my system is one big ridiculous loop with multiple inputs and outputs, so I canāt seem to isolate it, or figure out what is causing it.
I donāt wanna takeover this thread, but if anyone has any good resources to fix this or advice please message me.
I have the Zen Can and Dac for around three months now (With the DT880) and I didnāt notice any sloppy bass until I brought a second hand hd600, the bass is a lot tighter on the 600 imo.
That being said knowing that my DT880 can be much better is great news, any amp that I can get to replace my Zen Can? or should I balance mod it instead?
So I think my amp is broken. However I found this thread where someone is describing the exact same issue that Iām having, so I wonder if maybe they all have this issue? Or one bad batch?
ground loop hum no matter what I do. Even if I disconnect everything else from the system and itās just the source and amp. No issue when using the same components to a speaker. Tried all 3 inputs with phono, and RCA/Aux with digital. Hum in every combination.
when the source is coming in through the 4.4 pentaconn (which is input 3), if I select inputs 1 or 2 and increase the gain, I can hear the music (with no source tied to the empty ports). Clearly an issue hereā¦
Iām even using their fancy ipower that came with it as a release version.
Going to contact IFI and the retailer and see what they say
