Hey, I didn’t see a dedicated thread to this unwanted child so I figured I’d start one. If you own one, I highly recommend getting some micropore tape and putting some over the front pressure release port to balance the sound and get some low end thump. I am not displeased with my purchase post mod and in fact I use it daily for work due to the outstanding comfort it provides.
I think oval nozzles should be used more often and more research thrown at it as comfort is fantastic. I have not felt the need to tip roll from the stock tips due to the comfort it provides. I have not really had QC issues with mine from what I can tell so that may be a consideration post reports of mmcx issues and imbalanced units.
