I'm curious, are the thx900s still worth it?
Just throwing this out there to get some opinions, they can be bought used for pretty “cheap” now, should I still consider them, or are there better cheaper options put there with the same or similar sound signature?
I think they are for sure, and you can also Lawton mod them too if you want
