Dear HiFi-Guides
I play drums in a semi-professional band and have been doing so for years.
My IEM’s: KZ ZS10 PRO + Comply Round 2.0 TRZ-500 (shuffling between M and L)
The one thing i prioritize the most is isolation. Since we play with tracks, I first and foremost need to be able to hear the click. The overall sounds comes second, as long as I don’t ruin my ears in having to turn up the click too much because of bleed.
The above-mentioned equipment is cheap but effective on the isolation-front. Nevertheless, there is a slight bleed coming from the instruments. I found that after each gig, my ears are ringing. Therefore, I spent $360 on a pair of custom made tips (silicone) to replace the foam ones. I found that they weren’t much better, but definitely more expensive. I took them back to the store and had them refunded. I’m thinking, maybe I have to turn up the volume, not only because of the bleed / isolation issues, but because there aren’t enough drivers in my KZ’s?
I therefore have 2 possibilities from here:
1). Combine foam tips with more expensive IEM’s than the KZ’s. Something like Shure SE535-CL.
2). Go all in and buy Ultimate Ears UE-6 Pro.
I don’t mind cashing in against tinnitus. But I’m not even sure the second option would be the best concerning isolation (the main focus here!) because I worry they will be bad isolation-wise, just like the custom made tips I had made for my KZ’s?
Before spending this kind of money on experiments, I’d love to get some advice. For example: Would any of you say that UE customs are way better than custom made silicone tips, or are they plain similar? If the latter, I will of course go for the first option. Likewise, did any of you buy expensive IEM’s for your foam tips, only to find it made no difference, because the foam simply didn’t isolate enough, no matter what IEM’s you had?
I hope you understand and are able to help.
Thanks beforehand.
