I have a tendency to kill Toslink Cables with bend radius issues and moderate handling. Does anyone know of a type or brand or link that ones that can handle rough handling. Ideally one that could survive more than a month and one that can go above 24/96. I am reluctantly willing to go up to 100USD. Links or advice would be helpful. (Except for advice from a Capt. Obvious that says don’t bend it at a small radius, because well , duh ).
the amazonbasics ones are pretty flexible I haven’t had issues so far
Monoprice has one that is super durable but sacrifices some flexibility Amazon.com
and another that I am currently using with my main setup that is a good balance
(couldn’t find on amazon or Monoprice must be discontinued)
I think I figured out my issue , I need a 90 degree adapter so I don’t have to bend it so severely . Thank You for the suggestion.
