High wattage low ohm power amps + car audio subwoofers in a bedroom… easy spl fun??
example:
1 of these…
Behringer NX1000 1000W 2-channel Power Amplifier | Sweetwater
simple. fun. I’m missing something. :[
…right?
example:
1 of these…
…right?
Not sure the quality, like 5/8" construction isn’t the best. If accurate a 23hz tuning on the port is a surprise. But, I’d agree that it’s a lot of boom-boom for not much money.
What’s your use/goal though?
My plan for awhile has been a large Dayton HO or Ultimax of a Crown XLS. Big sealed.
It was just example items, and honestly it’s a case of put in earplugs (maybe depending on sq and spl), lay on my bed, and get a massage. (it’s cool too)
Chances are a Rythmik sealed 12 with 4 butt-kickers (1 strapped on each corner underneath my bed) hooked to each other would give a much better result for a musical massage. I WANT MY BALLS TO SLAP MY ASS!!.. when I turn it to max, otherwise a calming rumble is better :]
If i really wanted to go for quality I would custom build boxes for ultimaxes lol, the value of car subs in prefabs are undeniable though
5/8 with proper bracing is not bad at all
also, better example;
JL Audio CP212-W0v3 BassWedge™ slot-ported enclosure with two 12" W0v3 subwoofers at Crutchfield
Sure. One thing you’ll want to ensure is a 4ohm final load will be ideal if bridging the Pro Amp. The built-in xover options on Crown XLS stuff is so much nicer than the back switches on this Behringer.
I would plan on just using two subs to keep the ohm load down and power high, maximize efficiency and stuff. good to know about the crown stuff tho
