What does hifiguides think about intergrated amps, any good ones under $1000.00 ? particularly the mass produced brands D/M yamaha pioneer etc.? These stereo amps class AB ? can you go through computer hdmi-tv-optical-intergrated amp or is it better to go computer USB-DAC-RCA amp CD imput (pure direct feature yamaha ). I like to have foobar on a wall mounted TV while listening to stereo. Thanks for any reply.
I think there are a good number of options depending on what you want to prioritize, headphones vs speakers and what I/O options you need. Examples would be Denon PMA600ne, PS Audio Sprout 100, Peachtree Decco 125, NAD 3020 mk2 or 3045
Straight stereo but like to use my laptop connected to a second display with a turntable and 1st headphone at some point . Nothing fancy, prefer to get all from amazon. $600 neutral speakers cheap 10in sub. If i get that denon should i use a external DAC ? Im coming from an AVR.
If you have a good DAC already, it wouldn’t hurt, though I think the internal DAC is decent. Haven’t actually heard those listed, but gathered ones I recalled from past research.
I think the PS Audio Sprout may have what you’re looking for. And they do 30 day 100% money back no questions asked.
This is like audiophile class D ? I kinda want to go old man hifi class AB ZZ-top streetrod, the sprout seems like its a 2021 porsche all electric 911 ? If that makes sense, im a rookie at HIFI stereo. What really like to get is something like that yamaha A-S220SL with the analog VU meters, jeebus $3999 !
Fair enough. Ton of integrateds out there to choose from.
Thanks man. Just thought of something im doing it wrong if i dont get speakers that can do full range. Could i get away with bookselves playing orchestra ? Im i on the right track.
Orchestra is pretty dynamic and “full range”. If you can do floorstanders it would be better. I would look for something on the sensitive side (90+ db) or you will need a lot of power to get good dynamics. Def get your speakers sorted out first before looking for an amp because the speakers will dictate what an amp needs to do.
Get it.
(Chuckle) thing cost more than my entire HT.
Since you’re going over budget, might as well get one of these.
They throw the entire parts bin into that luxman and its glorious.
Shifting gears a bit sound artist any good ?
Come on, Looks like a damn holley dominator !
It does look nice. Just buy it and be done with it. You obviously want to lol.
That’s a sexy bastard for sure.
Go AB… Class D isn’t qite there yet.
