iPhone OTG Cable
I was just wondering if anyone could recommend an iPhone OTG cable to micro-usb for use with the Mojo. Right now, I’ll using an adapted cable in addition to the OTG, and I want something cleaner. I’ve struck out twice with cables that didn’t work on Amazon-hoping someone can rec a decent one.
Thanks,
May not help but the Apple Lightning to usb cable might help…Think it is the camera adapter?
Lightning to USB Camera Adapter - Apple
or maybe
Lightning to Micro USB Adapter - Apple
https://www.amazon.com/gp/product/B07KG6RLH7/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
I’m hoping to get something like that–just a short little cable with no adapters. This one seems like it should have worked, but I wasn’t getting any signal. Could it be the cable is just bad?
Forza Audioworks I think made a custom camera connection kit cable that allows for exactly what you are asking, I can’t find it on their site, but you could email them to see what they could do?
One came with my fiio qs5, so maybe someone with a portable fiio product also has one they would be willing to part with. Found this one on Ali Express.
https://m.aliexpress.com/item/32867374943.html
