I’ve been sending the digital audio signal from my iPad to my Schiit Modi then later the Modius with a USB-C to Micro-USB cable. Now I want to send a digital signal from my iPhone to the DAC, but there’s no easy Lightning to Micro-USB cable. I tried the Apple-provided Lightning to USB-C then this USB-C to Micro-USB cable adapter, and it didn’t do anything.
I feel like someone else must’ve been able to do this. How did you send digital signal from an iPhone to a DAC that takes Micro-USB, like Schiit?
Yes really .
You then only need to connect the cable that came with the Schiit to the USB adapter and that’s it.
I also had the Ddhifi and didn’t like it, it wore out after plugging it in and out a few times.
I barely touched the cable and the connection was lost.
Linking the Apple Camera adapter that we’re all talking about, this is also what I would recommend:
And yeah, I had the same experience where using a normal Lightning-to-USB-C cable doesn’t work for whatever reason, but I’ve used this adapter and it definitely works.
