Is cable balanced if it uses 3,5mm TS connections into both cups and xlr termination
Hi,
Im a newbie. I order balanced DIY headphone cable to my Arya Stealth. My single ended Arya cable, that came with headphones had two 3,5mm TRS connectors going into cups. New cable came with both 3,5 mm TS connectors and xlr termination going to amplifier. Is the new cable still balanced if it has TS connectors instead of TRS?
YesπŸ˜„. Each cup just need one positive and one negative lead. It is the amp end that determines balanced or not. There you need 4 or more separate contact points.
