Not at part of that chain but I suspect you’d get improved sound plugging your headphone amps into the SMSL 500 instead of into the Scarlett. You can configured your Scarlett as an audio input DAC and the SMSL as an auidio output DAC.
Aahh so you’re looking for hearing yourself play. yeah my recommendation was for improved playback. to hear yourself play and to hear yourself play with little delay your original setup is ideal.
So i notice a different when not using my m500 DAC in the chain…
Here is how I’m getting the best result for listening to music (pretty typical…) :
Computer => DAC => Headphone Amp => Headphones
But I cannot hear myself play guitar this way, so to hear myself play, I use this chain :
Computer / Fractal FM-3 => Audio Interface => Headphone Amp => Headphone
Essentially exchanging the M500 DAC with my Scarlett 8i6 3rd gen audio interface.
I would like to figure a chain that gives me the same audio quality with my guitar modeler plugged in.
Note: My Modeler, Fractal FM-3, can also act as an audio interface with decent DAC and Headphones amp capability. But again considerable difference compared to say RNHP.
Solution : Get an Audio Interface that has amazing DAC capability (or at least up par to the M500)… does this exist?
@FiCurious, so if I plugged the 8i6 to the M500 via the SPDIF out of the 8i6 to the Coaxial IN of the M500… the signal sent to the M500 will be Digital?
I just want to make sure there isn’t an extra conversion step I don’t need here.
Correct. It’d send the digital signal to the DAC to handle the conversion to Analog.
I’m sure @M0N could direct you to interfaces with higher quality DACs inbuilt, but I think that’s going to generally end up being a bottleneck in the chain afaik.
So you could get a nice studio adc/dac and use an external preamp for your mics and guitars which would work nicely (or you could get just a better interface as well), but it might get a tad costly, but it pretty easily can be done, just depends on how many channels you need
If, I was somehow certain it was better than the M500, I would probably get it.
It would simplify my current setup, for not that much of an upcharge (considering I would likely sell the m500 and 8i6)
But it’s a big IF. Lol
I personally don’t need a lot of inputs. 2 is more than enough. In fact : one would be sufficient! Two is future proof if I wanted to record with dual mics or something like that.
So I think it would be an upgrade in refinement, impact, potentially better spatial recreation, but similar detail and both are somewhat neutral although the apollo would be a bit warmer slightly
I mean in that case, you could get a nice studio adc and some separate mic preamps to go along with it, but that might be fairly overkill for what you are after, if you are looking for an all in one solution the UA would offer you a ton of functionality and good sound quality for it’s form factor
I don’t think that’s exactly what @sluice is after, he is more looking for an audio interface with a better dac at this point for recording and studio work, not a DDC
In the same time, I don’t really need a mic preamp, nor a good ADC at the moment.
I connect my Guitar Modeler via SPDIF to my Audio Interface.
So my signal is already Digital.
Eventually (In years? When kids grow up a bit), I might go back to actual mic’d cab recording for guitar, but it’s out of the question with 2 kids under 2.5 years old…
I do, but it’s only slightly and if you don’t plan to use the adc and preamp aspect it’s most likely not worthwhile to only use as a dac. I mean you could get something like an adi 2 pro fs, dangerous music convert 2, lynx hilo usb or tb, etc if you wanted a very capable dac and adc/digital interface
