Found dynamo 300s on ebay for 175 FS and was wondering if they would beat out the jamo c912?
the jamo will dig slightly deeper and fill a larger room. however, the dynamo will sound better. how much better and if its worth getting if you already have the jamo is debatable.
Not the only one reporting the money was spent on the sub not the packaging, Mine arrived with a dent and the foam in tiny pieces.
The C912 still going however after a month, so Jamo be there.
