Hey guys! Hope everyone’s enjoying their Friday - let’s talk about the JOYODIO Shine.
So, when I first got into the IEM rabbit hole I had the “pleasure” of listening to some early KZs and CCAs, and frankly they were terrible. Now, in 2023 you would think an $80 IEM would sound a lot better, but, unfortunately the Shine reminds me of those early days although without the nostalgia. But before we start I want to thank Linsoul for sending me these - unfortunately I just can’t recommend them, but feel free to check out their other stuff.
Anyways, starting with the low-end - it’s pushed back. It lacks the impact and slam even when I compare it to a cheaper set like the Waner and Hola. Out of all the switches the Standard has the most low-end, but it still sounds weak and low-res. I don’t know what driver they’re using but it’s not a high-quality one that’s for sure, and I also don’t recommend the Standard switch because not only is the bass light so you can’t really feel anything, but it’s also not very detailed, and on top of this you also run into the issue of masking with the added mid-bass - so it’s just a lose lose lose situation. The R&B tuning without the mid-bass sounds the best since if you’re not going to get quality bass anyways, you might as well not have it get in the way and mask everything. So I just end up going with the R&B switch as default because all of the other ones are not good.
Moving on to the mids - they’re recessed, and vocals are way too harsh especially female artists like Taylor Swift, and pretty much most female JPOP and KPOP artists. The boosted 1-2K area masks instruments like pianos and brass and over sharpens higher notes on woodwinds and horns. The sharp treble on top of this takes away your focus from the mids, so you end up just getting a lot of harshness and fatigue without actually hearing the midrange details (there’s also a mid-scoop on many of the switches). The only upside is that with the R&B switch at least there’s no mid-bass bleed or masking, but everything just sounds unnaturally harsh and thin. I literally couldn’t finish Hi High by Loona and almost died at the 2:40 mark - and the hifi, pop, and classical switches just makes things worse because now you have even more treble and less bass.
To make things worse, on top of this harshness you also have very peaky and uneven treble region which makes everything even harsher, and unlistenable. I mean the graph literally looks like a rollercoaster, and the peak around 15K really sealed the deal. Electric guitars, cymbals, and female vocals are sharp and harsh even at mid-volume. I had to turn it down just so my ears didn’t die, but at that point the low-end is basically gone, and you can’t hear the mids because they’re even more recessed now - so all you hear is the treble, a hollowed out midrange and vocals, with a lifeless low-end. The hifi, classical, and pop switches makes this even worse because they actually RAISE the treble even more and lower the bass - like why? Why? This isn’t even a treble-head set at this point because it’s so harsh and not smooth - the Shine is basically for people with high frequency hearing loss.
Now, I tried to save it by putting on Hana filters, and it did help tame the treble and make the Shine listenable at mid-volume, but the bass was still lifeless and vocals (1-2K) are still harsh. The dynamics are just absolutely horrible on this thing - I have to constantly readjust the volume every 15 seconds or so. There’s also just so many better options out there - like the Quarks DSP is literally $15 and craps all over it, well to be fair the Quarks DSP craps on most sets regardless of price, but even the LAN and Hexa are better and doesn’t kill your ears; what’s the point of having 4 tuning switches if they’re all bad?
I really don’t understand how any reviewer can recommend this with a straight face - I’d be really cautious of their intentions otherwise because the Shine is one of the worst sets I’ve heard this year. Also, the inside of the case is falling apart after a few days of use. I mean… At least it looks nice??
Anyhow, thanks for reading!
