I’ve had my LSR305s for about since 2015, and I’ve loved them. They’ve been really great speakers to mix with but I’ve had a problem with the left channel resonating. I put them horizontal, which fixed the issue, but is not the recommended position for optimal listening. https://www.youtube.com/watch?v=gbb-IbeX5nA this video is hilarious to listen to it on my JBLs.
So, the 305p MKII’s are on sale for $89 (!!), bit the bullet, and are arriving Monday.
I tried to fix the problem with stuffing tissues behind the woofer’s baffle/waveguide, and it didn’t really help.
If I get time, I’d like to do a side by side comparison.
The 305mki flimsy? front plastic’s and loosen screws in someway have been reported in many causes. It should be easy fix.
MKii should have more tougher front cover. Never know how it will hold time.
Update! Loosening the screws on the baffle on the woofer fixed the problem. I just sold the MK1s I just sold to a buddy, so no comparisons, but they are very similar, trust me ha
They were in the living room for a couple of days, and now they’re going to another fellow audio engineer. And, I’m going to have to act surprised on Christmas when my wife watches me unwrap the Micca OoOOOOOOOooooos
So I’m looking to purchase a pair of these, second hand. I was thinking of using them in my living room, in a relatively small apartment, would they be fine for this use? Or should I use them as desktop speakers?
If just for casually use to music and tv. They do pretty good job, only that they need’s to space behind them, bass will be heavy and effect the room a lot.
Have some absorbing material and port’s plugged, they are bit to close to wall but it’s alright.
Good and cheap.
