Klipsch rp 600m good receiver combo
I used a sealed Rythmik and it performs superbly for both, but I’ll tell you that your budget will get expensive very quickly.
Ehat does wasapi do in foobar2000 in both event and push.
Oh how am i supposed to see the menu of my receiver if i only go directly from my pc to the monitor? I assume that i can’t change the bass and treble without the menu.
it should have its own small display that you can change those things on . you shouldnt have to mess with them more than a couple times
so i purchased the 3.5 to rca cable and i am quite happy with the result. now my question is could i use my receivers remote to change the songs from foobar like i can with bluetooth.
no, you can buy a remote USB infrared receiver for your PC and program the remote to change the tracks on your PC from a distance.
Or even a full USB wireless keyboard with media keys.
any recommendations. i need one that is good and that has backlit keys because i have a visual impairment. and would need help spotting the keys. thank you for the help.
My wife bought me that amp for Christmas and I love it, very powerful for 25wpc and sounds great.
