Got my KZs, they sound great but I get a constant hissing even with the volume knob all the way to the left, is my pair defect? I’m using it with a Aune X1S. No such hissing or static with headphones, only my Sennheiser Momentum IEMs but only audible at like unlistenable loudness settings like 1 o’clock.
Is it because of the impedance?
It might be because that most iems are more sensitive to hiss because of their higher sensitivity and lower impedance, allowing you to hear an audible hiss with some amps with a decent amount of power or poor construction
It’s probably because your phone puts out much less power and the amp inside the phone was most likely designed to be used with low impedance high sensitivity devices like easy to drive headphones and earbuds
The aune x1s also has a fairly high output impedance, and while that won’t really effect many headphones, it can be not ideal for iems. The aune really wasn’t made for use with iems
It’s definitely sensitivity, get something like a UE noise buffer or ifi iematch to resolve the issue, if using the iems with your x1s is absolutely necessary.
Something like electrical noise, probably. I definitely don’t hear it often, and the music definitely needs to be off to hear it. Really subtle.
I used to have computers with noisy mechanical hard drives, so I’m used to “hearing things” when a computer is busy. One day I was just browsing the web and as I was scrolling down the page, I heard this noise. Then I’m like… Wait, my smartphone doesn’t have a mechanical hard drive! Lol.
Yeah, they are a treat for the price, I’m really enjoing them on my phone as of now for listening to drum and bass and tech house, they are punchy in such a good way. Definitely keeping them and buying a ifi iematch to use them on my aune, it will come in handy later on for something like the oh10s I bet.
I was actually surprised knowing that im not the only one, i bought the Kz zsn pro X, it has the same issue of that sudden click on the left part i got relieved knowing my pair isnt really broken
