Kz ZS10 pro X 2. 5 mm balanced cable
Hello everybody.
First of all, I would like to say that I am not an audiophile, and my knowledge is very limited.
I bought a qudelix 5k and kz zs10 Pro X, and I want a cable to take advantage of the 2.5 balanced output of the qudelix.
Can someone suggest me a cable? The problem is that all the QDC cables that I see have pin 0.78, and the Kz have pin 0.75.
Thank you so much for your help.
Tripowin do QDC cables suitable for KZ, available from Linsoul
XINHS on AliExpress has a wide range of cables for KZ including modular cables allowing you to change tips from 3.5mm to 2.5mm and 4.4mm. You can even have custom lengths.
https://www.aliexpress.com/item/1005004521624876.html?spm=a2g0o.store_pc_promotion.promoteWysiwyg_2002487301871.3
I have multiple cables of this type. Hope this helps
Of course that it’s helpful!!
Thank you so much!!!
Just ordered the tripowin zonie right now.
Thanks again!
the only difference between balanced and 3.5 is that balance is just louder.
I hope the balanced is shorter and gets less tangled.
Loud… Well, now is louder enough.
I’ll let you know.
Thanks!
Well, the box came opened and the plastic bag didn’t look new.
The sound is louder but with a lot of distortion.
Sent back and I’ll keep my stock cable.
Thanks to all!!
