Which would be a better pick for the Headphones I own?
6xx
58x
elex
m1570
Sendy Aiva
Aeon OpenX
Hifiman Ananda
Or is there something else in the 600 usd price bracket i should be looking at?
6xx
58x
elex
m1570
Sendy Aiva
Aeon OpenX
Hifiman Ananda
For those headphones imo def the liquid plat. I would suggest you stick with a hybrid with all the planar you have imo
Perfect. Going to try to cancel my lafigaro order and buy the platinum. The next set of cans i might buy are the meze empyrian
Any tube suggestions for it? Im not opposed to trying some other tubes if it makes it even nicer.
I have heard some nicer tubes on one and it does improve the sound, but I can’t give you any suggestions here personally
Awesome guess its research time. Thanks for your help.
And as a bonus the Platinum is on sale for $599.00.
I like the La Figaro, but you’d only have success with the Sennheisers on it. It’s better than the DV for planars, but definitely not ideal
