which gives better sound quality theoretically?being the q5 got better internals but the audio is being used as a bluetooth
do you need a more powerful amp? if not then the V30 is worth it
Regular apt x or apt x hd?
regular aptx
As far as I know aptx is 352kbps max., so it’s more than enough for “bitperfect”
320kbps mp3s.
Obviously CD-quality files are 1411kbps, so if you’re using uncompressed files… I’d choose wired.
@JEFF_JEFF There ya go.
