Excuse the noobish question (still new here)
On the fiio q1mk 2 there is a “line out 3.5mm port”. If I want to use it only as a dac will I be able to plug it in to an amp via the line out port? Is that what a line out is?
For example, I plug in the qmk2 with usb for input, plug in 3.5 aux from line out for output into amp (probably jds labs atom) and it should work…?
