Hey guys, new member to your forums, I hope I posted in the right section ![]()
I own the Fiio FH5, and though the sound quality is stellar, Fiio’s cable has disappointed me slightly.
I own two OEM cables, and on the first and older one, the MMCX plastic housing straight up shattered around the left port. This was under normal use, never dropped them, stepped on them or hit them with anything, so I suppose the plastic used for the MMCX plug housing is just brittle.
The second and newer cable is OK so far, and while it was nice and soft when I bought it a few months ago, it all of a sudden hardened as if it was made of plastic, not rubber mesh (or TPU whatever it is). Every individual wire that leads to each earpiece (after the splitter) now feels so stiff, as it would almost be able to hold the weight of each headphone. I suppose the problem here is that the TPU they used for newer or more recent cables is different from the one used on older ones, as I never had this problem with the older cable. The problem with it hardening is that it increased microphonics considerably, because the noise from every tap of the cable travels better to the earpiece housing, not to mention mobility sucks.
My questions:
I noticed in one of Z’s recent reviews, that this cable was recommended, and seems to be a great deal, however, I have a couple of questions for some of you who might use it:
• On Amazon, someone mentioned that the cable has microphonics, however, someone else states the opposite in a different review. I suppose this is subjective, but has anyone noticed this to be a problem? I should mention that I’ve purchased an aftermarket cable a while ago for my Sennheiser IE80, and while it looked silvery and shiny, it turned out being extremely stiff and had horrible microphonics, to the point where it was unusable if you moved even slightly, so I am now hyper-aware of this issue.
• The MMCX connector version of this cable appears to have straight connector plugs, whereas the connector plugs on the OEM Fiio cable are slightly curved to “lead” the cable towards the back of the ear. I was wondering if anyone used the MMCX version with the Fiio FH5, or FA1, or FH7 headphones, to know if that kind of wire plug shape would work well (comfort/fit-wise) with the headphone shape/housing?
Thank you guys, looking forward to hearing your thoughts!
