Ahh ok i see what you were getting at
The mx3 i can use the 3.5mm plug in set it to absolute zero and then rca to the little dot to avoid double amping would that work?
You would still be double amping, so still not ideal but you would just want to make sure you set the volume on the mx3 where you donāt hear any distortion, and you should be good enough
Ok because i can set it to absolute zero db
And hopefully it wont distort
If it doesnāt distort you should be fine
Ok thank you lots for all the information
The LD II should be fine with headphones rated between 30-600 ohms if you use the internal dip switches to match the hpās requirements
These are valves I use for mineā¦
Ok thanks what do you mean by internal dip switches?
Sorry Iām a bit busy at work at the mo buddy but this should help explain a bit more about the LD MK2
http://www.popular-hifi.com/projects/nad_stereo/little_dot/little_dot_mk2_manual.pdf
Thank you very much i was not aware of that and i will be sure to fiddle with them thats super helpfull as my headphones dont take very much power to run so thank you big time
I donāt use HPās that often now due to being more into IEMās but when I do, I like this chain iFi Micro iDSD > LD MK2 > Senn 660ās ![]()
Thank you for this - Iām trying this with a Sabaj PHA3 cheap hybrid but not really hearing any difference.
So my next train of though was exactly getting a LD mk2 instead to get a real tube amp with line out and try it. Though at the moment Iām watching a mk3 on eBay⦠and a BHC and some DVā¦
The bottlehead crack is a large step up from the little dots and the darkvoice, but for your application it wouldnāt work well since it has no pre or line outs. Also look out for some eddie current jrās as well in that price range
Hmm now that I look at it closer this doesnāt look like any other BHC⦠https://www.ebay.com/itm/353179854787?ViewItem=&item=353179854787
Yeah thatās just a generic design, not bottlehead
Reminds me of the guy on here (sorry canāt remember your name) who ordered a bargain DV? and ended up with a costume jewellery ring lol
ah yes @Andrew_Davis and giova lol
Yes Andrew thatās the chap
Iām not the only dupe who paid for an amp and got toy jewlery. But I was one of them!
It was a pretty obvious scam.
But what can I sayā¦hope springs eternal.
