Turco
January 8, 2020, 4:49am
1
Been debating on getting a tube for my HD600. Was looking around and I could get a Little dot mk2 at about half of the price of the darkvoice. Is the Little Dot Mk2 still a good choice for a tube amp or should I save up for a Darkvoice?
Would be paired with a Topping D10
M0N
January 8, 2020, 4:50am
2
I think the little dot mk2 is pretty nice, but I personally prefer the darkvoice as I think it pairs better
Turco
January 8, 2020, 5:10am
3
Ok sweet, thanks for the input. Also any tube recommendations for the HD600?
M0N
January 8, 2020, 5:13am
4
I would try out stock first and then there
There are a few already existing darkvoice tube threads
Got my Darkvoice a few months ago and the stock tubes were pretty good for me, but it was my first tube experience (so nothing to compare it to) but everyone says they are trash so I decided to invest $40 into a pair of RCA tubes that don’t sound much different to me (although it is hard to compare tubes when you have to warm them up in between, unless you have two amps). So I wanted to see what everyone’s experience is with darkvoice tubes. It seems to be a fairly popular amp considering Zeos h…
So I’ve been running my Darkvoice SE solo since I recently switched to a SDAC-B from my O2/ODAC combo and am waiting till November for THX789. I tried using the SMSL SAP VI, but the sound felt claustrophobic, so I decided a couple months maining a tube shouldn’t be too bad (despite using Plainars on it too) with my HD 650. I was trying to look into tubes to alter the Darkvoice a bit, but I’m just not seeing a place to buy that seems reliable.
First off, what size tubes does the Darkvoice use an…
Turco
January 8, 2020, 5:16am
5
Ok awesome, Ill check them out thanks.
