What do you do to keep your headphone in tip top shape?
I have a sizeable collection of headphones so i dont wear out most of them that fast but as i spend longer and longer in the hobby - maintenance is becoming more of a thing.
Normally i give a few spritz with some 70% alcohol with a through rubdown with a microfiber cloth. but ive decided to add a yearly routine
- Leather - (mostly the headbands), some leather cleaning cleaner/conditioner
- Metal - a light rubdown with a microfiber cloth with a little bit of WD40
i though at first that just the alcohol alone would be enough but i recently noted this nastiness on my Meze 99 that could not be cleaned with water/alcohol regardless how much you scrub (after a good cleaning with leather cleaner it all came out)
Still looking for a good wood and fabric cleaner/conditioner (the regulars ones ive come across have a smell which i really dont like)
