I finally got my hands on a Schiit Heresy after an absurdly long waiting time. It should arrive at the end of this week.
Now to my question which would be a good DAC to pair the Heresy up with?
Currently I use the DT 990 (250 ohm) & MMX 300 2. Gen.
Would it be worth to wait for a restock on the Modi 3+? Or are there maybe better options in the same price range?
Forget the Modi and get the Khadas Tone Board ($99) or a SMSL Sanskrit 10 Mk II ($109). Both sound better and have more features and better measurements than the Modi.
Yes and no. Yes to complete a stack for a matching look, no as in most DACs under 200USD sound more similar than different so you should go for whatever is available if urgent
I had a Modi 3 when I had a heresy. It sounded great but I don’t think it supports DSD. Yeah I liked my Modi / Heresy stack when I had it. It’s really up to you as, far as waiting for a Modi but there are definitely better DAC’s out there in that price bracket.
Available in EU and genuinely a good DAC at the $200ish price range. You’re going to want a linear power supply for it down the road to improve the sound even further. But this DAC will grow with you.
