Looking for a replacement amp to power a set of Micca RB42s
So as of right now I am using a topping PA3 to power a set of Micca RB42’s in near field on my desk. The amp “works” but I would like an upgrade as I have a few issues with my unit.
The first issue is that while it has functioned for a few years now there is always that nagging feeling in the back of my head that the topping poor reliability will kick in and burn the apartment down.
The second issue is that while it normally provides enough power, I find that I feel like I need jut a little more in the head room department. As the amp is both very dirty as you get closer to the top end. Ive also had instance where I am listening to some quieter audio that I just can’t get quite loud enough.
Other then finding something without these issues, things I am looking for in an amp would include the power transformer built in instead of relying on a detachable brick. Small enough I can fit it on the deck, I’m a tad tight on space. As for budget I don’t want to bust the piggy bank so prefer suggestions under 250 American.
while it has an external power brick I use a smsl DA-6 with my MB42xg2, low gain around -40db is usually what I run it at (goes down to -59 up to 0)
maybe something like the smsl A300, same amp chip but more features/power and no brick.
are you near max on the volume knob on the amp? Sounds like you may be clipping it.
Unfortunately, my best options for “small and works” require detachable bricks but: In the past I used an SMSL AD18 with a pair of RB42s in our lab rooms at work, and they always managed to drive them well to a point where too loud is too loud. There may be a better modern option but I never had a complaint with it when I used it. Another option that may not be as high-powered but is pretty clean from what I hear is the RSL iA255.1. Should be more than enough for nearfield, has tone controls AND a dedicated sub-out with high-pass, all for ~$110. Plenty of reviews on it out there if you want to give it a look, and RSL lives and dies by their customer service.
That was one of my candidates but went with the Douk A5 since it was cheaper, more powerful and uses a pretty popular chip nowadays (TPA3255)
It varies for some things I have to crank it for others I have to turned way down usually its somewhere in between. But I do feel like there is something wrong with my audio chain to cause so much variance.
Which ones for which problem?
The RB42.
  • Impedance: 4-8 Ohms
  • Sensitivity: 83dB 1W/1M
  • Power Handling: 15-100 Watts (Each)
Weird impedance rating but the PA3 has:
  • Maximum output power: 80W x 2 (4 ohms), 70W x 2 (8 ohms)
    You really shouldnt need more power than that,
With 80db and +20db headroom, you need 50w if you are using it in near field setup. Which is more likely to be around 0,5m and not 1m.
Which would need 12,5w.
They always list the RB42 as 4-8ohm and I treated them as 4ohm just because. Per ASR, it dips to 3.6: Micca RB42 Bookshelf Speaker Review | Audio Science Review (ASR) Forum
The issue is I think the amp is defective and my unit is not performing like I feel like it should. The volume settings I’m constantly having to change depending on use cases. Music to YouTube to gaming and the signal gets very dirty very fast.
Yeah that sounds off then. Although volume can change from local files to YT and gaming. have you tried using say a wired iem/bud/headphone to check the if the volume difference is still a thing?
No I have not, And yeah I get that sound level will vary normally. Its just a tad jarring at times. Back of my mind thinking I’m looking for an excuse to get an upgrade lol. That said I have less issue with variance with my Headphone amp that I have hooked up to the same audio chain.
Sounds like a defective speaker amp then.
3e A5 (or A7)
PFFB that is exceedingly well executed. It’s replaced my $6000 250W@8Ohms hybrid class-A tube amp. Looks like they only have the A7. The A5 makes plenty of power and has slightly better technicals. Might keep an eye on it as it’s cheaper too but if you don’t want to fuss just order the A7.
https://www.aliexpress.us/item/3256807777869502.html
Is there a place to read up more on this product? The product page seems a bit bare. I am not a hige fan of ordering direct from Aliexpress due to shipping times and effectively no warranty or return-ability.
They link a few reviews but other than that not that I’m aware of.
The company has been making amp modules as an OEM for sometime and apparently for some of the expensive makes too.
This is there first non-kit offering and it’s clear they are engineers and not marketers.
I had zero issue with my order but it’s the first time I’ve used aliexpress. I do know that the link is to their store, not a 3rd party.
Ah, when the A5 comes back in stock ill have to consider it. At the moment I think what I am looking for is more so something that can fit on the desk. The area is kind of small, and provides clean power. I now don’t think I need lots of power just something much much cleaner then the PA3 that I am currently running. I was thinking the SMSL PA40 might work. Its about as big as I can go is size
Douk A5 is good.
