Finally got my hands on a 789 and would like to match it with a decent DAC with some specific features.
I’ve heard that the 789 has some issues with its volume, which can be avoided if you use it as a pre-amp and put the volume/gain to the max on the 789 and control the output volume on the DAC. Which leads me to this feature list that I’m looking for:
- Pre-amp capability (to alleviate the lowering volume issue on the 789)
- Physical Volume knob (not just remote)
- Bluetooth (LDAC or higher)
- USB / Optical Input
So far I’ve been looking at:
- Aune X8, but it doesn’t have Bluetooth
- SMSL M200, but it doesn’t have pre-amp
- Topping D50s, weird volume knob, no pre-amp
Maybe I’m overthinking the 789 volume issue and should just go for the SMSL M200 but I don’t really like the slanted look of it unless it’s sitting on a SP200
