I’m looking for a 4pin mini xlr cable,(Audeze), to dual 3 pin male xlr cable to use with my Mjolnir. I can’t find anything, other then 4 pin xlr. Anyone know where I’d be able to find something? I’m looking for a quality cable, that can ship to Canada. I’d prefer to stay away from cheap cables and would prefer to buy something made in America, preferably not made in china. Budget isn’t much of an issue, but would want to keep it under 700$.
This would be for an LCD x and LCD 2c right?
Would norne audio work? Something like the drausk would be a nice choice and can be dual 3 pin to fit that requirement imo, although not sure on shipping to Canada
I would also mention double helix cable but imo I think things like the complement c might end up getting more than I’d suggest spending in this case
There’s also articcables, they should offer what you need, but I haven’t heard any of their new models
There are other good options too but not sure if they would offer dual 3 pin
Yeah its for the lcdx and lcd2c, Articcables doesn’t ship to canada, but the other 2 do, norne audio’s site isn’t secure though, which is kinda sketchy to put any billing info. the helix does ship and seem to offer what I was looking for but its going to be about 1000$ CAD, I’ll have to think about it, I’ll keep looking around. I just want to try out the amp’s different balanced outputs, with a decent cable. I did look at some other sites like corpse cable, but some of them don’t ship to canada.
You should be able to use paypal checkout iirc which should be safe, but idk otherwise
Good quality cables but yes the price is high in this case, I personally wouldn’t spend that much for a cable for a lcd x or 2c, I guess unless you go for their cheaper option
Also a wywires platinum should be pretty good and be able to be spec’d with dual 3 pin and could be a good option
zynsonix? The ballista is decent and it does come with dual xlr as an option for the amp side, although imo it’s lower quality than the other aforementioned options
Hart Audio Cables Custom Shop?
Thanks for the suggestions, I’ll have to research and check them out.
