check the guide or other commons that I bring up… 560s, 58x jubilee, 660s, 400se
any of the above. 990 is quite sharp though. as far as comfort goes I find beyer or sennheiser the best bet in most cases. 880 is probably the best bet in many uses less you dont plan to upgrade at any point.
I know you didnt ask me but Im personally tempted to. but the 600 ohm 880 whoudl run fine. it wont be at “full potential” but it definitely has enough power to drive it loud it will just not asound as good as something more powerful
different signature, better for those without equipment or low budget / not wanting upgrades. 880 has a more balanced signature overall and can be a bit more flexible through pad swaps than tygr… overall 880 600 ohm is a better headphone but tygr fills a particular niche for gamers
I think sivga sv021 is quite comfotable for long gaming time.
As for the sound, you need to try it out if you like it. I use it when I play God of War and Devil May Cry, and the experience is not bad.
yeah, but a lot state they arent sensitive to the treble only to find out 990 really is full on piercing to them. I want to second the 880 in this case… its just a better more flexible choice and it doesnt have the bass issues of the 880 for competitive gaming… that or the tygr but tygr doesnt scale
