I have had some.. issues with IEMs recently and Im looking for something new.
I really liked my 10BA per side Nicehck NK10s, but one of the broke - just makes a scratcing sound. Could have spilled water over them. Anyway.. ordered the Nicehck SP12 as replacement - those got lost in mail and i just got my money back
Currently using P1, Ikko IH10 and Blon´s - none of them is quite my liking. Ikko has too much unnatural bass, lacking in vocals. P1 is too harsh and small sounding and the Blons are not TOTL by any means in my opinion. If you somehow got them to fit and not fall out of the ears then the sound is decent, but when you have heard better then its kinda meh too.
I was looking at Dunu dk 2001 / 3001 pro, fiio fh7, mofaset trio hybrid, tansio mirai tsmr 4
Would like to spend less rathen than the whole 500, but that mofaset trio is juicy
I use Etymotic ER4 SR IEMs, the deep fit is not for everyone but the balanced, neutral very accurate sound is superbly done. And the passive noise isolation is outstanding. Good build quality, well accessorised and well within your budget.
I will bring out this old thread - sorry Anyway, went to Tidal on my phone and will buy the Fiio BTR5 from Penonaudio. Then I thought maybe should get some new IEMs too.
500 is bit much, maybe 300-400. I have been recently using OH10s, but those are too V shaped for me and bass is bit much. Do like the comfort and build. I also have a pari of NiceHCK SP12, but those are bit bright and fatiguing for me - 12BAs per side. Sounds detailed, but bit unnatural.
So probably looking for something more neutral sounding. Width is always good. Those Dunu and Fearless mentioned earlier are bit much atm, so decided to ask for more ideas since I have not been watching any IEM related videos/reviews since like January
Does anyone have the Dunu 2002? I heard Porta-fi guy saying they are the most natural of the line. Though they seem out of stock in Penon and not available in linsoul either.
