Looking for IEM reccomendations
Looking for new IEMs.
$100 USD budget. (Willing to push it abit)
Shortlisted Tin T4’s (i can get them for ~$80 on aliexpress)
Currently using Pinnacle PX’s & HD 58x’s
Any suggestions are welcome! Thx :3
Edit:
I listen to J-pop, electronic, jazz aaaand i think thats it.
I personally like the 58x’s sound signature, sry im not very knowledgeable about these kinda stuff :confused:
Edit 2:
i can get the Shouer Tapes for ~$120USD, will it be worth it to go for that?
What do you listen to? Also what type of sound signature do you prefer?
Since you listed T4 as a possible candidate, check out Jade Audio EA3 or guideray gr-i. Both are 50 and under and I prefer over the T4. EA3 if you want lots of clarity and detail with good bass and the guideray if you want more of warm tilted signature with a more musical sound.
Thx! I will check em out!
If you like the 58x instead of the t4 which I personally really like. Maybe moondrop starfield might be a better direction
Shozy 1.1 would also be on my list.
Very curious to see how I like that when it gets here
