My sister is looking for light and small headphones.
She has AKG K-72’s which fit my head, are too big for her though.
My Porta Pro’s have the same size issue resulting in excessive pressure on the ears (even in the light setting).
She wants open back.
EU (Germany)
50€ soft limit
no amp
I am thinking KSC75’s (30€) may work, maybe Sennheiser HD-100 (31€)
Unless she’s going to be bothered by the clip, KSC75 is a good option. The KPH30i has less clamp than the Porta Pro, btw. That may be very nice with some Yaxi pads.
Can you get a parts express headband where you are? Probably KSC75 is indeed the best option. If she doesn’t like clips and Parts Express is available, you can get their cheapo headphone for headband donation.
Check on Massdrop the Emu Purpleheart.It cost a bit more but it worth it.
Is lite on the Head,a very good Soundstage,and good for little Ears.
Actually Massrop have the Walnut edition online but i don‘t know how good it is.
I had luck it passed to the Custom so i don‘t have payed tax for it.
It‘s a 50:50 chance.But the Tax are not expensiv when pay it.
Definetly fits the light and small. Question is in fit.
Are TRRS to 2x TRS cables somehow non-existant? Spent the past hour looking through products and found cheap-AF ebay thingies or hand crafted for 40€.
The impossible cable…
