BL-05 is most definitely brighter than the 03, the opposite of warmth.
ZS10 Pro from what I remember and know, is a V-shaped iem. Which means it got recessed vocals.
05s! Sorry ![]()
I really can’t hear that at all? So either I got fucked up ears or a fucked up set of ZS10 Pro’s xD
They might have neutral or a bit forward female vocals but recessed male vocals. Its not strange and is a strategy used on a lot of budget iems (especially the older ones).
I really dont remember how the ZS10 Pro sounded so I could be wrong though…
I do prefer female vocals on them over male so you’re probably right yah
Be careful of the treble on the KZ ZS10 pro. I don’t know if it is just the frequencies or also the BAs they use, but it is one of the more painful trebles to me.
Depends on the IEM. You do need to do a bit more research when looking at cheaper IEMs since there are more misses then in more expensive ones, but there are also some real gems too that punch far above their weight class. Also with the shotgun style a lot of ChiFi companies take it is surprisingly easy to find all sorts of different sound signatures in one of the many many releases they do.
Is it tip Dependant?
i don’t think so,but most of the time I use SYMBIO hybrid tips on my iems
