Currently I’m using a custom Ipod Classic with the Wolfson DAC
I’d like for it to be able to use Spotify which I think means I would need android based but I’m also potentially willing to sacrifice that if the player is worth it
Right now I’m going in between Moondrop Starfields and GR07’s
If it matters I mostly listen to rock and metal but a little bit of everything
I know some others find the slightly laggy performance (speed) frustrating, but I really like the Hiby R5. Full Android and plenty of power to drive most anything…and sounds good
Ah! I missed that earlier. I think the M11 is right up your alley! You’ll get used to the U/I interface pretty quickly. And operating within your streaming app of choice, you won’t really notice anything android. Then the fiio music app is actually REALLY pleasing for anything you want to play from a micro SD. Definitely a safe buy!
