I currently own the s12 Pro and really like the clarity and the brightness.
I wanted to get some recommendations for something under $400. I prefer a sound with slightly more treble and would like something with better technical performance than the s12 pro.
In terms of music I pretty much listen to a mix of genres, usually more towards alt rock and r&b.
try this eq preset if you need a better treble focused sound signature or a very mild u shape. with the lowered bloat and less 2k shout you will get noticeable “soundstage” or “technicality” boost for free.
Preamp: -3.3 dB (for s12 pro)
Filter 1: ON PK Fc 70 Hz Gain -6.4 dB Q 0.400
Filter 2: ON PK Fc 410 Hz Gain 0.4 dB Q 2.000
Filter 3: ON PK Fc 660 Hz Gain 0.5 dB Q 2.000
Filter 4: ON PK Fc 1500 Hz Gain -2.0 dB Q 2.000
Filter 5: ON PK Fc 2200 Hz Gain -3.4 dB Q 1.500
Filter 6: ON PK Fc 3100 Hz Gain 1.8 dB Q 2.000
Filter 7: ON PK Fc 3300 Hz Gain 3.6 dB Q 2.000
Filter 8: ON PK Fc 4600 Hz Gain -1.4 dB Q 2.000
Filter 9: ON PK Fc 5700 Hz Gain 1.1 dB Q 2.000
Filter 10: ON PK Fc 8000 Hz Gain -5.3 dB Q 2.000
Filter 11: ON PK Fc 14000 Hz Gain 3.5 dB Q 2.000
preamp -2.5 (for s12)
Filter 1: ON PK Fc 90 Hz Gain -4.8 dB Q 0.400
Filter 4: ON PK Fc 2200 Hz Gain -5.9 dB Q 1.500
Filter 5: ON PK Fc 3100 Hz Gain 1.8 dB Q 2.000
Filter 6: ON PK Fc 3300 Hz Gain 3.6 dB Q 2.000
Filter 7: ON PK Fc 4600 Hz Gain -1.4 dB Q 2.000
Filter 8: ON PK Fc 5700 Hz Gain 1.1 dB Q 2.000
Filter 9: ON PK Fc 8000 Hz Gain -5.3 dB Q 2.000
Filter 10: ON PK Fc 14000 Hz Gain 3.3 dB Q 2.000
