Looking for the best bang for the buck, compatible with V-moda boom mic pro
Hi
I want to upgrade my setup but I’m struggling to find options anywhere!
As of right now I own a pair of Sennheiser HD400s and 4.40BT both have 2.5mm jack on them with a lock.
I also have a V-moda boom mic pro.
My goal is to find a good pair of headphones under 100$ or around that price, if they’re worth it, that are compatible with the boom mic (headphones with a 3.5mm input port).
I’ve been searching and the only headphones I find, either have 2.5mm with a lock, like mine, or they don’t have a detachable cable.
Also already read other posts similar to mine, but none had viable options.
Any suggestion is appreciated.
Thank you
The first that comes to mind is the Philips 9500.
