I’m looking for some low profile, in ear [audio devices] that don’t protrude outside my ears a lot for bringing to work. I’m currently using Tin T2’s with comply foam tips under peltor ear muffs and at the end of the day I am in extreme pain. Not looking to spend a lot, and sound quality doesn’t need to be life changing, just need podcasts and music to drown out the lawn mowers and equipment.
Check out the Blon BL-03s, I fall asleep in them quiet often and wear a set at work all day.
Do you think the BL-05s are gonna hold up? Or is it just not worth the fuss and $15
I’ve not heard the 05s, liked the 03s enough to order a second pair off Drop though.
Ikko OH1’s are snug and low profile. You may forget they’re in your ears.
Blon 03 is better for me. And it is less fatiguing too, so it will suit you better.
BL03 sound great and have a low profile fit that I can use under noise cancelling headphones. However, they have very low noise isolation just like the Tin T2.
Tin-hifi P1
VERY low profile and you get a super detailed IEM.
Got the BL03 shortly after posting and was so happy with them, almost exactly what I was looking for. Have had problems with them recently where after about an hour of use the left channel will slowly go quiet until completely silent. But they’re so cheap I don’t feel too bad using them practically disposable. I use them at least 30 hours a week so I feel like they have served their purpose over 6 months. Will probably try the bl05s next cuz I probably don’t wanna rock FH7 with a weedeater.
sounds like a moisture issue with them…
They get back the sound after you let them “rest” for a while right?
Take a look at the mesh on them, to see if it is clogged up or anything.
