LPVO - Vector Continental 1-6x24 - SFP
Review - https://youtu.be/PsPdpEVTcgs
Comparison - https://www.youtube.com/watch?v=vunLIEfme5s&t
Acquire - https://rebrand.ly/immc6ko (Capped Turrets)
The Run Down:
  • Chinese made
  • Around $300
  • 11.1” Long
  • 16.9oz
  • Excellent Illumination
  • Tight Eyebox
THIS Continental follows its siblings in almost every way but one. The Eyebox is on the tighter side. I go over this in depth, and showcase it in the review heavily. It might not be a deal breaker for you. And if it isnt, then I think you would be very satisfied with this optic. I would highly recommend adding one of their new throw levers to your cart if you decide to buy any of the Conti lineup.
If your seriously looking at this optic but arent sure if its the best fit for you. I go over many great options for you. If you want to stick with Vector, the 1-8x24 is a Superb all rounder. And something that I would personally use if I needed the 1-8x mag range (https://rebrand.ly/ic4ae6o)
