Hallo should i get m40x+brainwavz hm5 angled sheepskin or takstar pro 82? Both have same price 97 dollar. Thank you
I like netral sound.
I thought you he m40x was pretty bassy. I haven’t heard the 82, but I have the cooler master mh751, and I think they are better all around (and way more comfortable).
Not sure where you’re located but the 82 is only $50 on eBay:
Wow that so cheep. But i think they not shipping to my country. Im from indonesia. Is m40x have more bass than takstar pro 82? Because the seller in my country says that pro82 is vshape and m40x is more flat. Thank you for replay
My understanding is that the Pro 82 has some sort of bass adjustment, so it can have more or less bass depending on your preference. I would definitely consider the m40x a bassy headphone.
you might want to consider a Sennhieser 58x you can find them used. they are neutral but have a lot of good base. I have one and they sound amazing
Thank you sr .
That out of my budget haha. Sennheiser is very expensive in my country
That is a good question though. Do they have to be closed-back?
