I’m not really set on M40x’s as they are meant to have better bass but not as good as the MH752’s for gaming. I was also considering the Alpha’s, as they have pretty good build quality, but sound isn’t as good as MH75’s for example. So which one for the best competitive gaming experience under $200AUD? I was really torn between the Alpha’s and MH75’s but everyone seems to have such varying opinions. Price doesn’t matter, as long as it’s within the budget, so if Alpha’s are overpriced but better I wouldn’t mind.
The cloud alpha are not better than the 752 . The alpha is based on the takstar pro 80 which is noticeably muddier and not as good for gaming as. The takstar pro 82 which the mh752 is based off. The 752 is also noticeably comfier and generally just the better headphone off the 2
Oh ok. I’ve just heard a lot of build quality issues with Cooler Master, like their mice, such as the MM710 which I plan on getting if they have fixed the problems and the MH752 if they have addressed the screw falling out issue.
